Old 04-17-2012, 04:40 PM   #1
sugar ray
AKA: Sean
Vehicle: 2002 Grand Am
sugar ray Gettin' there
P0128 - Coolant thermostat
02 Grand Am 3.4 SES light came on today on the way home from work.
Pulled code with my OBD reader. Getting P0128 - Coolant thermostat (Coolant Temp Below Thermostat Regulating Temperature)
Thermostat a simple replacement, any chance the sensor is TOAST or a new thermostat should cure the problem?? It has NEVER been changed. Probably should have replaced it when I did the lower intake gasket?? No big deal!!
Just lookin for a few experts to chime in here... thanks
sugar ray is offline   Reply With Quote
Old 04-17-2012, 10:09 PM   #2
shiwnath
shiwnath's Avatar
AKA: Trevor
Vehicle: 2000 Olds Alero Sedan
shiwnath Gettin' there
Is the car getting up to normal operating temperature? When my thermostat went, it was stuck open in the middle of this past winter and I couldn't get any heat and it was staying around or below the 1/4 mark. To be honest I'd start with changing out the thermostat because it's most likely cheaper than starting with replacing the sensor. Plus it couldn't hurt to change it after so many years anyways.
shiwnath is offline   Reply With Quote
Old 04-17-2012, 10:27 PM   #3
x2 same here
Old 04-17-2012, 11:24 PM   #4
sugar ray
AKA: Sean
Will attack this within the next few days. Thanks boys!! Will post my results.
Old 04-18-2012, 05:05 AM   #5
not a problem
Old 04-24-2012, 12:38 PM   #6
bmoc0129
AKA: Joshua
Vehicle: 2002 Grand AM Gt1
bmoc0129 Gettin' there
I wish I knew how to replace the thermostat and sensor...because I pulled the same code not too long ago. Also saw something about an EGR valve.
Have you tried adding coolant (if it's low)? I saw somewhere that someone got their light to go off after doing that.
bmoc0129 is offline   Reply With Quote
Old 04-24-2012, 07:05 PM   #7
UndeadGods
Ram Aired!
UndeadGods's Avatar
AKA: SinSki
Vehicle: 03 Grand Am GT
UndeadGods Gettin' there
I doubt it, my car leaked massive amounts of coolant and the light never went on, blew a head gasket, the light never came on =/ haha
UndeadGods is offline   Reply With Quote
Old 04-25-2012, 09:49 AM   #8
rocketfast123
Was i drunk that day
rocketfast123's Avatar
AKA: Tater Salad
rocketfast123 Gettin' there
When my friend had the P0128 on his 99 V6. It was the sensor. On cold start the fans would go to full speed after about 2-4mins. And the trans would act funny.
Old 04-26-2012, 11:52 PM   #9
sugar ray
AKA: Sean
UPDATE:
Weird....may be leaning towards a sensor?? After posting.....I went back into my car and cleared the codes (knocked out the SES light) with my OBD2 reader. I realize that kocking out the light does NOT solve the problem. Figured I would do that on my way down to the auto parts store. Expecting the light to come back on. It didn't?? Anyways......picked up a thermostat but have yet to put it in. Drove for over a week with no codes or SES light. Then again today....light was triggered and same code appeared. Cleared the code and all was well again.
It operates at normal temperature. Not over cooling or under cooling. Normal as it should be and still have plenty of heat from the vents. I did both the LIM and head gaskets just over a year ago. It's not losing any coolant internally or externally. Car runs like brand new. This code just randomly pops up about once every 7 days??
WTF??
Old 04-27-2012, 12:33 AM   #10
i could be wrong.. but if you keep clearing the code with the OBDII scanner, it will keep coming back until the problem is solved.
when i replaced my thermostat, i replaced the coolant sensor too. and everything was all fine after that.
Old 04-27-2012, 01:11 AM   #11
HOYS
lolGM
HOYS's Avatar
AKA: Colin
Vehicle: 2001 Impreza 2.5 RS
Conditions for Running the DTC
The engine is running.
DTCs P0112, P0113, P0117, P0118 are not set.
The ECT is more than -40C (-40F).
The ECT is less than 78C (172F).
The intake air temperature (IAT) is more than -7C (+19F).
The engine has been running for more than 2 minutes, but less than 30 minutes.
The vehicle speed is more than 24 km/h (15 mph) for more than 1.609 km (1 mile).
The mass air flow (MAF) average reading is more than 15 g/s.
Conditions for Setting the DTC
The PCM detects the following:
The calibrated amount of engine run time has been met.
The calibrated amount of engine air flow has been met.
The calibrated ECT of 80C (176F) has not been met.
Essentially your thermostat has failed and it is designed to stay open when it fails, as to not cause harm to the engine. If you engine does not warm up to at least 176* F it will set the code.
Replace the T-Stat (don't remove the lower bolt fully as the t-stat neck is slotted for that bolt) and go from there. If that does not fix the issue (code will have to be cleared, code will go away after 40 successful warmups) then replace the ETC. I'm betting it is just the T-Stat.
