Old 12-05-2010, 08:19 AM   #1
dand2392
porfessional thug
dand2392's Avatar
AKA: dan
Vehicle: 03 grand am gt
dand2392 Gettin' there
Led smoke taillights
anybody have pics of these installed? i am interested in seeing the third smoked brake light installd, ...and the main lamps as well. I just bouthgt these and they comin in the mail
http://cgi.ebay.com/ebaymotors/99-03...T-/360324896402#ht_4752wt_1165
dand2392 is offline   Reply With Quote
Old 12-05-2010, 10:18 AM   #2
I have smoked lens LED tails on my car. Just not those exact ones, the other style. And not the third brake light.
Old 12-05-2010, 10:26 AM   #3
just to let ya know.
i dont have that style but i used to have the red 3rd brake light.
it will have a dim glow to it when the car is running an also at night when the lights are on.
which will also in most cases cause you to loose your CC. adding a few resistors will greatly help, or doing the Impala 3rd light mod
Old 12-05-2010, 04:24 PM   #4
I have those or very close to the same ones, including the smoked 3rd brake read this thread I had trouble with the Cruise control though never with the lights staying on ever. I fixed the cruise problem its all in this thread
Got Headlights and Tails
Old 12-05-2010, 04:33 PM   #5
Actually this one has the Cruise control the last did not
ABS light
Old 12-05-2010, 07:27 PM   #6
I actually just did the Impala LED 3rd light mod an my CC now works...never had any kind of idiot lights on the dash but CC never worked once i installed Ebay LED 3rd
Old 12-05-2010, 07:36 PM   #7
so a 2.2k resistor on the 3rd brake light restores cruise? that's it?? i was going to use the load resistors that were going to be for my turn signals..
you da man!
this just needs added to the positive side wire or jumped across them both (pos and neg)?
Old 12-05-2010, 08:43 PM   #8
you da man!
this
Old 12-05-2010, 08:45 PM   #9
I had the abs light come on because I used too much resistance my first resistor was 3.9k that must have tripped the brake switch in the abs computer.
Old 12-05-2010, 08:54 PM   #10
you da man!
send out the lifeboats, you da man OVERBOARD!!! wooot wooot
Old 12-07-2010, 04:05 PM   #11
dand2392
porfessional thug
dand2392's Avatar
AKA: dan
thanks for all help
Old 12-08-2010, 04:20 PM   #12
I unplugged the clip, fed the leads down into the female ends of the clip, left enough lead for it to lay up top like this, and clipped the plug back together. fwiw i used a 1/2w 2.2k resistor- 99cents for a pack of 5 @ radioshack.
I realized it may get warm, so I'll keep an eye on it, I don't see it melting the plastic covering, but if it does, oh well I'll move it
Old 12-08-2010, 04:30 PM   #13
Pretty cool lights if smoked.
Seems a bit ridiculous that it would mess with your cruise control though.
Stupid GM.
Old 12-09-2010, 12:26 AM   #14
That is the way I did mine at first, testing purposes, then I soldered it, to make sure it would not come loose from vibrations.
Old 12-09-2010, 07:41 AM   #15
Stupid GM.
It's not stupid GM it's stupid aftermarket companies. They are putting in a type of light that wasn't designed to be there from the factory, and if you need to add a resistor for it to work properly with the brake light circuit, then they obviously didn't do their job right.
GM designed the automatic shut off for the cruise control to work when the brake lights come on so it would shut off when you apply the brakes. It works fine in stock form. It's not GM's fault if you modify your car and things no longer work as intended.
Old 12-09-2010, 01:19 PM   #16
Sorry I would still fault both. CC should turn off when pressure is applied to the brakes independent of the electronics having to do with the actual bulbs and electronics in the tail. It'd be like limiting your speed to 70 when your headlights are on because you shouldn't be driving as fast at night.
They're 2 completely different systems in my mind.
Old 12-09-2010, 01:35 PM   #17
I agree they should have used the cc cutoff on the pedal switch.
Old 12-09-2010, 06:43 PM   #18
yup i think it's a very shoddy system, using the brake lights to kill cruise.. lame. but it's simply a 20 cent fix, so i guess it could be much worse.
Old 12-09-2010, 09:47 PM   #19
What do you think turns on the brake lights?
A switch on the pedal, duh. Why place extra switches when you can have one do both? Simplicity of design and cost savings wins out over any retarded ideas you guys have about proper system operation. Leave the engineering to the engineers.
Old 12-09-2010, 09:51 PM   #20
this is exactly my point the switch on the pedal could easily do both, why the extra of having it measure the lack of resistance at the tail lights
brake, led, lights, smoke, tail
