#1 |
Grand Am Lover
![]() AKA: Rowe
Vehicle: 2002 Grand Am Gt coupe
99 grand am gt (front end wrecked)
hey guys,,,been a while.
just had an accident today and my front end is very damage. i was wondering if there,s a how to on replaceing the whole front at on time(fenders and front) heres some pics thanks for any help. ![]() ![]() ![]() |
#2 |
![]() AKA: Greg
Vehicle: '05 SC/T
First you need to ensure there is no frame damage...check body panels the whole way back. Then you have to get the parts out of the eay and survey the damage. I'm not a body man so I usually reference gmpartsdirect.com for their images and part numbers. You can buy new parts or you can utilize car-parts.com and search a multitude of auto recyclers for what you need.
3400 Built from the ground up including a m62 Supercharger kit and full custom exhaust. Getrag F23 swap is next once tuning is complete and it's too cold out to go outside. Custom FBSS Air Suspension built and installed. |
#3 |
Grand Am Lover
![]() AKA: Rowe
thanks,,,,but im looking for a list and pics of the nuts and or
bolts need to be taken out to remove the whole front end at one time. |
#4 |
Grand Am Lover
![]() AKA: Rowe
also need to know what years and model front ends
will fit on my gt,, example 2002 se model |
#5 |
![]() AKA: Nathan
Anything 99-05'se and gt will fit the car. There is now pulling the front end off at once. Its not a late 80's ford truck.
You need to pull the bumper off separately, then remove the hood (4 bolts) remove fenders one at a time, and thats it. Then just replace the parts.
2001 | Alero GLS | 3400 | 6MT ![]() 2012 BMW S1000RR, full exhaust, BRENTUNE, power commander 5, dyno tune, 198WHP. |
#6 |
Grand Am Lover
![]() AKA: Rowe
![]() ![]() ![]() ![]() you da man |
#7 |
![]() AKA: Nathan
Yup always here. Just dont post much anymore unless i can help
![]() Really not hard though, see a bolt, remove it. Still cant remove part? Look for more bolts ![]()
#8 |
![]() AKA: Greg
Vehicle: '05 SC/T
If you are looking for a how-to then a haynes manual will provide what your looking for, if you prefer pictures then the link I provided offers images similar to what i have attached here in addition to valuable part numbers since I assume you will want to put the car back together. Most junk yard GA's have too much damage to be used so I advise using the second link for quality used parts without having to travel and pull or pay for new parts. I have lots of parts images to get you going but sleepy is correct in saying pull bolts n clips til it is free. Based on your level of damage I'd say many of the clips are already removed.
#9 |
Grand Am Lover
![]() AKA: Rowe
thank you guys,,,that will get me started.
appreciate all the help n knowledge. ![]() ![]() |
#10 |
Grand Am Lover
![]() AKA: Rowe
well the frames bent,,,wonder how much trouble it is to
change the engine out into the 4 cylinder gt body? another body with the 4 cylinder engine if possable. |
#11 |
![]() AKA: Erik
Anything is possible. However changing a v6 to a I4 or vice versa in our cars isn't a cake walk. You would need to change out the entire engine wiring harness and the ECM as well. A N-body isn't worth that hassle.
2000 - GAGT 14.63@92.9 -Full LX9 with CAI, 65MM TB, 2.5in DP, Borla Cat-Back, Crappy rubber, Magic, Quick tune) 2008 - Kawasaki Ninja 250r - Slip on exhaust, K&N, Jetted, Sprockets, Lowered and the Girlfriend's now 1984 - Honda Nighthawk 700s - Oldest, quickest and quietess |
#12 |
![]() AKA: Nathan
DO NOT SWAP A 4cyl CAR TO A V6!
ive seen quite a few people who have attemted it, got the car running and working. But just had so many problems with it its just not worth it. Save yourself the hassle, buy another v6 car.
#13 |
Grand Am Lover
![]() AKA: Rowe
thanks sleepy,,,,thats just what i did,,,but this one has a knock in it.
could it be knock sensor or clogged oil filter or worse a rodbearing? its a 2002 gt 3.4 litre v6 with 156000 on it. |
#14 |
![]() AKA: Nathan
A knock sensor wont stop a motor from knocking. How bad is it, does it get quieter once car is warmed up?
#15 |
Grand Am Lover
![]() AKA: Rowe
a litlle,,,it seems alot queiter when driving at a steady speed,then gets noisier when accelerating or letting off the gas.
#16 |
Grand Am Lover
![]() AKA: Rowe
so what ya think?
Thread Tools | |
Display Modes | |
