Old 09-19-2016, 04:01 PM   #341
The_Maniac
AKA: Jason
The_Maniac Gettin' there
Originally Posted by DavidSinger77 View Post
Does anyone know someone who is selling the z-spec supercharger kit that rsm made? I'm looking to pick one up for about 2000
Hardly related to this topic. This should be a tread in the wanted section.
'04 3.4 Grand Am GT SCT
'84 5.0 H.O liter v8 Z28 Camaro (L69 Engine)
'04 3.8 Monte Carlo SS
http://www.crzyz28.sytes.net
E-Mail: The_Maniac@sbcglobal.net
The_Maniac is offline   Reply With Quote
Old 09-19-2016, 06:02 PM   #342
He posted in 4 different sections, including the wanted section.
Old 10-04-2016, 12:08 PM   #343
_HeC_
_HeC_'s Avatar
_HeC_ Gettin' there
3" downpipe, wanted it to be 1 piece but wasn't happening
Girlfriend painting all the exhaust parts with some POR-20 heat paint
Some heat management
Quick clean to make sure no debris was inside
Notch for oil return
Screamer pipe
Turbo 3500/5 speed swapped
The Build
IG - turbogagt
Old 10-11-2016, 06:19 AM   #344
_HeC_
_HeC_'s Avatar
_HeC_ Gettin' there
Words can't describe how much I ****ing love this thing! Lol
Quick driving video
Old 10-11-2016, 03:20 PM   #345
It is pleasing to see your ride is now adorned with accoutrements and weaponry worthy of the title-
BADA$$ !!
Nicely done!
_HeC_ for President!
Old 10-11-2016, 07:07 PM   #346
How long until you take it to the track and give it the kind of engine-bashing good time we're all wanting to see?
Old 10-11-2016, 08:47 PM   #347
Well done. I worry about that intake pipe restricting flow. I wonder if you had a clean/mandrel bent pipe if it would benefit you with more power
Old 10-11-2016, 09:16 PM   #348
3400cavyhatch
Vehicle: 84 Cavalier Type 10
3400cavyhatch Gettin' there
Probably won't make any difference. Sloppymechanics did a before and after dyno with two different charge pipes.
1993 Chevy C1500 3100v6 turbo
2004 Alero 3400 bone stock with a cheap muffler 15.32 @ 88.69
99 Alero 3500 swap running(from 2.4). ported and polished heads. totaled by a honda
2002 GAGT 3500 swap
3400cavyhatch is offline   Reply With Quote
Old 10-16-2016, 06:12 PM   #349
_HeC_
_HeC_'s Avatar
_HeC_ Gettin' there
Haha thanks guys, don't think I'll make the track this year but never know! Needs to be tuned before I can really get on it
As for the pie cut charge pipe, I don't think it will make much of a difference but I tried a piece of mendral bent pipe and it was too close to the turbo IMO. I only used 10-15 degree cuts so the inside still flows rather nicely I think but outside looks like poop my welds got a lot better towards the end of this project but ohwell
The Build
IG - turbogagt
Old 02-08-2017, 07:43 PM   #350
GRAD SCHOOL FUN
Yo its been a minute where you at
2000 - GAGT 14.63@92.9 -Full LX9 with CAI, 65MM TB, 2.5in DP, Borla Cat-Back, Crappy rubber, Magic, Quick tune)
1984 - Honda Nighthawk 700s - Oldest, quickest and quietess
Old 02-21-2017, 03:17 PM   #351
_HeC_
_HeC_'s Avatar
_HeC_ Gettin' there
Someone stole my 4x4 and blew the engine up so driving it right now
The Build
IG - turbogagt
Old 02-21-2017, 06:23 PM   #352
what?!?!?!?!?!
Old 02-21-2017, 09:01 PM   #353
what?!?!?!?!?!
Yeah his jimmy got stolen. Found it a couple days later there was a hole in the block when they found it.
Old 02-22-2017, 06:48 AM   #354
_HeC_
_HeC_'s Avatar
_HeC_ Gettin' there
What sleepy said except it took like a week for the cops to find, called me and said bring your keys it looks like it's in good shape still....
Pool of oil under the truck and nothing can go in the ignition cause of a broken piece of metal in the ignition, managed to fire it up and move it so the flat bed could grab it easy but damn it sounded rough haha
The Build
IG - turbogagt
Old 02-22-2017, 01:22 PM   #355
GRAD SCHOOL FUN
Damn that sucks man, hopefully insurance does you right.
Old 02-23-2017, 07:43 PM   #356
the dimes aren't worth 2 nickels to insurance. that sucks dude. the thing looks pretty decent too, you going to try to find another motor?
Old 03-04-2017, 03:39 PM   #357
plastic_indian
plastic_indian's Avatar
Vehicle: 04 2DS
Throw a used motor in that Blazer. Those trucks aren't worth sinking much money in, but they are solid, capable, reasonably well built and were pretty much the last of cheap/easy to buy and repair low-tech compact 4-bys.
The 4.3 long block will interchange several years beyond the end of S/T chassis production, so finding a low-ish mileage unit in the self service wrecking yard should still be possible. Find a promising candidate in the yard, pull the pan and bearing caps off. As long as the crank journals are standard and undamaged, drag it home, reseal it, maybe throw a new oil pump and bearings in it. A 4.3 almost always dies of a rod problem, so as long as the bottom end is clean and tight the odds are pretty good it will give acceptable service life.
Old 03-05-2017, 07:17 PM   #358
I love me some S10 they're like little 4x4 cavemen. I heart them so much
Old 04-16-2017, 09:23 PM   #359
_HeC_
_HeC_'s Avatar
_HeC_ Gettin' there
Ended up getting 3K CDN for my jimmy, no replacement truck yet but want something I can tow with
2 stage colder plugs, fresh oil change and new tune from Scott
Turbo 3100 swapped Sierra...
Killed my tires, new ones on next day or 2 and maybe a track day this weekend
Might need to purchase a helmet before the track day
The Build
IG - turbogagt
Old 04-16-2017, 09:32 PM   #360
3400cavyhatch
This thing is pretty quick, would really like to see how it goes with traction and a straight line! I don't see why it shouldn't do 12's this year if it hooks! I'm really starting to think of a 5spd for the Alero now too! Lol
2002 GAGT 3500 swap
