Go Back   GrandAmGT.com Forum > GAGT - Modifications - Sponsored by RedlineGoods.com > Wheels, Tires, Brakes, & Suspension
Closed Thread
Old 08-26-2005, 07:36 AM   #1
Molson
Admininadian!
Molson's Avatar
Vehicle: GMC 2500 HD & MKZ
Molson a trusted member
Wheel sizes, hubrings and more. READ THIS FIRST.
It's about time we had something like this.
Here is additional information you might find useful.
Okay, factory bolt circle pattern is 5 x 115mm. Factory 16x6.5" alloys have an offset of +42mm. You can also use 5 x 114.3mm or 5 x 4.5" (same thing). Though some have mentioned vibration problems with the 114.3mm rims and many others have had no problems what so ever. If you use 114.3mm rims you should also get hubcentric rings to fit them on with and check you lug nut torque a little more often.
What are hubcentric rings???
Originally Posted by mfuller
Hub-centric and lug-centric are two completely different things, yet they are both important to proper wheel fit.
Hub-centric means the centerbore (the large hole in the middle of the wheel) is machined to precisely fit on the hub of the vehicle. Now, since it'd be expensive to precisely machine the centerbore of every wheel to fit every car, manufacturers usually provide 1 or 2 centerbore sizes and rely on hub-centric rings to "shim" the centerbore around the hub for a snug fit. Why is this so important? The hub is meant to bear the stress of vehicle mass, not the lugs!
Lugs and lug nuts (or lug bolts on vehicles with threaded hubs) are designed for one thing - to hold the wheel onto the hub. That's it. Lug-centric means the lug holes in the wheel precisely match up to the lugs (or threaded lug holes) on the hub. If they are even the slightest bit off, it becomes difficult to maintain equal tightness on each lug, because when you torque a lug nut (or bolt), the torque center (not sure if that's the correct term, but anyone who has engineering knowledge knows what I'm referring to) is not precisely on the center of the lug - this is why it is so vital to check lug nuts for tightness on wheels without the proper bolt pattern. If you can't get equal clamping force on all the lugs, the possibilty for lug or lug nut failure is much greater.
Having a hub-centric wheel (or a wheel with hub-centric rings) is more important than a lug-centric wheel, but personally I wouldn't take one without the other, especially on the racetrack.
Just my two cents.
So, as a reference:
1. Bolt Pattern- 5x115 is the stock size, 5x114.3 will work with hubcentric rings.
2. Offset - +35mm to +42mm should fit. Offset is not the same as backspace!!!
3. Maximum Rim Size - 18" is the maximum recommended size. 19" have fit with very low profile tires, and 20" have fit with some suspension modifications to the strut perches.
4. Tire Size - Rule of thumb would be (based on rim width) 215-225 for 7" wide rims, 225-235 for 7.5" wide rims, and 235-245 for 8" wide rims.
5. H&R / Eibach / Intrax / Sprint lowering springs CAN be used without any problems on wheels up to 18". Above 18" depends on the wheel size et al.
6. The GA's Hub diameter is 70.3mm.
7. Pre 1999 GA's have 5x100 bolt pattern and +45 offset.
-For a great site to see how tire size affects your speedometer, click here.
-For more Info on Backspacing, click here.
For other sites for rims, try these sites:
http://www.onlinetires.com/main.html
http://www.1010tires.com
http://www.1stopcustomwheels.com/
http://www.800wheels.com
http://www.aaarims.com/
http://adaptivestrategies.com/
http://www.afftw.com
http://www.autoimaging.com
http://www.aktusa.com/wheels/wheels.html
http://www.azcwheels.com
http://www.b17a.com http://caraddons.com/Catalog/subpag...stom_wheels.htm
http://www.custom-wheels.com/cfwdpage.htm
http://www.customwheelsdirect.com/
http://www.customwheelservice.com
http://www.customwheelsmarket.com
http://www.cruisin-gold.com/
http://www.discounttire.com
http://www.dmtechamerica.com/
http://www.dtcmotorsports.com
http://www.ebay.com
http://www.emowheels.com/emo_site/c...r/wheelpage.asp
http://www.englishcustompolishing.com
http://www.finoswheels.com
http://www.flipstires.com/Wheels/body_wheels.html
http://www.german-wheels.com
http://www.gmpperformance.com/Default.htm
http://www.grouptyre.co.uk/asa_wheels.htm
http://www.gtautosports.com
http://www.goodroads.net
http://www.heavyreaction.com
http://www.hubcap-tire-wheel.com
http://www.importhookup.com
http://www.imoto.com
http://www.infinite-motorsports.com
http://www.inlinefour.com
http://www.jdmhondaparts.com
http://www.king-motorsports.com
http://www.metrowheels.net
http://www.mileone.com/mrtire/wheels.htm
http://www.modacar.com
http://www.overboost.com/obs/
http://www.ozzytyres.com.au/
http://www.precisioninstallations.com
http://www.rim1.com
http://www.rimstock.com
http://www.salesco.com
http://www.savastire.com
http://www.shinestreet.com/wheels
http://www.speedywheels.com
http://www.superbuytires.com
http://www.superlite-wheels.com/
http://www.tirepros.com/wheels.html
http://www.tirerack.com
http://www.ultrawheel.com/
http://www.usacomp.com/Road.htm
http://www.victoriatire.com
http://www.washingtontire.com
http://wheelfind.com/selling/
http://www.wheelsmarket.com/
http://www.wheelmart.com
http://www.wheelmax.com
http://www.wheeloptions.com
http://www.wheelsone.com
http://www.wheeltech.com/main2.html
http://www.wheelwarehouse.com
http://www.wholesalewheel.com
http://www.wholesalehyperformance.com
http://www.whalentire.com
https://www.woodfins.com/index.ASP
Sig
Molson is offline
Old 08-26-2005, 07:39 AM   #2
AMRAAM4
Wiley 'Ol Veteran
AMRAAM4's Avatar
AKA: Bob (aka Hoss)
AMRAAM4 a trusted member
Good work Jimbo. I have been thinking of doing this for awhile, but, I didn't have the energy especially when I know many won't read it first. Stickied at the top, and anyone who doesn't read gets their post deleted
New info will be added accordingly, locked for now to prevent people posting confusing and wrong info. If your wheel info doesn't fit this info then it is not a good wheel to buy
AMRAAM4 is offline
Old 03-30-2008, 09:00 PM   #3
Why the offset matters
Will 18x9 Rims fit my GAGT?
High Offset:
Low Offset:
Courtesy of AMRAAM4
fquick
Rich is offline
Closed Thread
