Old 10-05-2013, 11:22 PM   #561
Nick-G
Boost Addict
Nick-G's Avatar
Vehicle: 2002 Grand Am GT V6
Nick-G Gettin' there
Getting a little better at welding aluminum.
www.motorsportsevolved.com
Get updates on Facebook
Old 10-06-2013, 01:23 AM   #562
Welds look pretty good, what happened on the right side? Looks like too much filler, left side looks really nice though. Got any pics of your starts and stops? Usually where people struggle the most on.
Old 10-06-2013, 08:45 AM   #563
Slinky
AKA: Tyler
Vehicle: 1995 beretta z26 3400
Slinky Gettin' there
Basically the fuel feed line is split and feeds into both fuel rails rather than one. The fuel pressure regulator is just mounted inline before the feed to the rails.
It's hard to say whether or not it makes any difference at all but in theory feeding both rails should give me more consistent fuel flow to all the injectors.
So it goes feed from tank --> fpr --> both fuel rails?
So the return line to the fuel tank is just plugged now?
Slinky is offline   Reply With Quote
Old 10-07-2013, 02:31 PM   #564
I believe the after market regulator he is using has 4 ports. In other words, it has a supply and return port going to/from the tank, and two feed ports going to each fuel rail. That allows it to feed both rails simultaneously with constant pressure, instead of going through the rails first and building pressure on the back side like stock with the 2 port FPR. Many aftermarket FPR's are set up like this to allow flexibility in the fuel feed setup.
Anyway, it would still have to have a return line. You couldn't just plug it and run our pumps on a single line setup like newer cars have. They use a variable speed pump with a controller and an internal pressure bypass. If you ran our normal type of pump without a return line they'd burn up.
Old 10-09-2013, 04:47 PM   #565
GT_turbo
GT_turbo's Avatar
Vehicle: 2004 Ford F-150
GT_turbo Still kinda new, but learning
I think what this guy has done is amazing, don't get me wrong.
However, I do have a friend who was like this. He modified a newer generation Firebird for years, when he was done he drove it for 2 months like a puss and sold it. I see so much of him in this thread.
Miss my turbo Grand Am
GT_turbo is offline   Reply With Quote
Old 10-10-2013, 04:28 PM   #566
Nick-G
Boost Addict
Nick-G's Avatar
Well I won't sell it. I have however considered the possibility of swapping the engine into an f-body at some point in time.
Old 10-10-2013, 06:15 PM   #567
zukiracer19
BoOsTiN'
zukiracer19's Avatar
AKA: slograndam
Vehicle: ev0m0de
id say fiero.. super light... but very dangerous.
Old 10-10-2013, 07:00 PM   #568
Nick-G
Boost Addict
Nick-G's Avatar
I found the perfect fiero years ago. The body was mint and the price was dirt cheap due to a blown head gasket but I passed on it so I could finish the grand am.
There is a black 94 camaro for sale locally that has me interested though...
Old 10-11-2013, 04:59 AM   #569
zukiracer19
BoOsTiN'
AKA: slograndam
Vehicle: ev0m0de
Fiero!!!!! Old camaros are ugly
Old 10-11-2013, 08:08 AM   #570
And Fiero's are better looking?
They certainly aren't safer. I'd get the camaro over a fiero. Of course, the camaro is heavier.... I'd leave the engine in the GA myself!
Old 10-11-2013, 10:47 AM   #571
zukiracer19
BoOsTiN'
AKA: slograndam
Vehicle: ev0m0de
If done right they look very nice.
Old 10-11-2013, 03:14 PM   #572
1995quad4se
1995quad4se's Avatar
Vehicle: 1995 Grand Am Sedan
1995quad4se Gettin' there
Pretty sure we need to see some.numbers and times with the ga before it gets swapped.
1995quad4se is offline   Reply With Quote
Old 10-11-2013, 07:37 PM   #573
Agreed.
Old 12-06-2013, 10:25 AM   #574
Slinky
AKA: Tyler
any progress on this?
Old 01-14-2014, 11:57 PM   #575
dlineownzu4life
Not a newbie.
dlineownzu4life's Avatar
dlineownzu4life Gettin' there
Cold winter... Eh?
there boys.
Old 01-30-2014, 03:37 AM   #576
Slinky
AKA: Tyler
This guy alive?
Old 01-30-2014, 07:27 AM   #577
GT_turbo
GT_turbo's Avatar
See quote... there are enthusiast out there that do theses builds and get enough enjoyment out of building them that they never actually run their cars. Sad, but true... He did start the car up though, props for that.
Old 01-30-2014, 10:09 AM   #578
sassyness77
AKA: Richie
Vehicle: 99 Grand Am SE/GT/GXP
sassyness77 Gettin' there
Well I would say the -40 windchills here in MN may just be slowing progress a tad...
sassyness77 is offline   Reply With Quote
Old 01-30-2014, 10:29 AM   #579
Slinky
AKA: Tyler
was the car not in a garage in every pic?
Old 01-30-2014, 12:26 PM   #580
Yeah, it's in a garage, but he's not gonna go out and drive a car like that in weather like this. I believe it's mostly done, but if he can't drive it right now, he probably isn't in a hurry to finish the last details. Also people have these things called "life" and "work" that get in the way sometimes. Give him a break guys.
#speedtakestime, #tig welder ftw, i am dissapoint, y u no finish?!
