Old 09-10-2010, 11:49 AM   #1
tony111
AKA: tony
Vehicle: 1999 grand am
tony111 Gettin' there
please help transmission problems P0742
Here are the basics car is a 99 grand am gt has 11x,xxx miles on it. I went on a buisness trip was out of the country and my wife was driving my car up to her moms. The code P0742 came on. This happened twice on a long trip there and back.When I got home I did a fluid and filter change myself. Fluid wasnt burned but looked worn. Went to her mom's drove up there 280 miles no problems. Came back almost got home we were going up a hill it felt like the car ran over something and it started shifting harder and also P0742 came on. So either my car is low on tranny fluid which is possible or the solenoid is shot. What is odd is the ses light will go off when I put the car in park and it seems to shift smoothly. Any Ideas? So far this happened to me once.
tony111 is offline   Reply With Quote
Old 09-10-2010, 03:56 PM   #2
GA2000GTSpeed
GA2000GTSpeed's Avatar
Vehicle: 00 GAGT, 79 Jag XJ6
GA2000GTSpeed Gettin' there
Well have you had the P0742 code translated?
how much fluid did you put in when you did a fluid/filter change?
Does it shift hard into all the gears?
Did the magnet have a bunch of metal flakes on it or did you clean the magnet?
Current mods: RSM Supercharger kit, S&S Headers, Upgraded Clutches, Borla cat-back, Drilled and Slotted Camaro rotors and Calipers, MSD coil packs, EGR Block Off, 180 thermo, MSD wires, Tuned Myself with DHP, 2 12 inch Alpine type R's, Kenwood bass booster 1700 watt Amp, Red Dual flip down head unit, Tinted Tails, Custom Painted Black With Red Interior, Double pod A pillar, A/F Gauge, Vac/Boost Gauge.
Future Mods: Heads, P&P Intake manifolds, 65mm TB, HP Tuners, .
GA2000GTSpeed is offline   Reply With Quote
Old 09-10-2010, 06:17 PM   #3
How did you check the fluid level?
Old 09-14-2010, 05:49 AM   #4
tony111
AKA: tony
When i dropped the pan there was not alot of debris in there only a dusting of crap. The magnet didnt have any pieces on it only some black dust. When I changed fluid I was lazy and did not check the fluid level. I recently put my car up on stands and it was low a quart. This was added and so far it has not thrown the code. I did originally have the code scanned when it happened and it said the torque converter was not releasing ie p0742.
