Go Back   GrandAmGT.com Forum > GAGT - Technical - Sponsored by www.MilzyMotorSports.com > Warranty, TSB and Recall Info
Old 08-28-2002, 08:47 PM   #1
iceman
woop woop
iceman's Avatar
AKA: Seth
Vehicle: 97 Blazer - 84 Fiero
Index of all TSB's - Technical
#00-03-09-002 Rear Suspension Spring Squeak/Creak (Lubricate Lower Spring Seat) - (Feb 4, 2000)
#00-06-02-001 Engine Runs Hot, Overheats, Loss of Coolant (Polish Filler Neck/Replace Radiator Cap) - (Jan 5, 2000)
#00-06-04-009 Rough Engine Idle, Misfire, Possible DTC P0300 (Replace Spark Plug Boot Assem) - (Feb 9, 2000)
#00-06-04-015 Info - New Design Quick-Connect Fuel Line Fittings - (Mar 28, 2000)
#00-06-04-044 Engine Hestitates, Stalls, Will Not Start (Replace Modular Fuel Sender Strainer) - (Oct 16, 2000)
#00-07-30-012 Tech - Auto Trans Shift Lever Handle Difficult to Operate - (May 30, 2000)
#00-08-42-007B Stop/Tail Lamp(s) Inoperative or Intermittent and/or Water in Lamp (Replace CIrcuit Board/Gasket and/or Lamp Assembly) - (Jun 17, 2004)
#00-08-49-008 Broken Mounting Tabs on Console Rear Seat Cupholder (Replace Rear Console Housing) - (Aug 1, 2000)
#00-08-50-009A Pass. Seat Easy Entry Feature Does Not Operate Smoothly (Replace Seat Track Adjstrs) - (Dec 19, 2000)
#00-08-51-001 Outside Rear View Mirror Housing Turns Chalky/Dull (Color/Clear Coat Mirror) - (Aug 25, 2000)
#00-08-57-001 Front Carpet Wet (Replace Water Deflector) - (Mar 22, 2000)
#01-03-08-003A Squawk Noise From Front and/or Rear Suspension (Lubricate Stabilizer Bushings) - (Feb 5, 2002)
#01-03-10-009A Plastic Wheel Nut Covers Missing and/or Loose (Replace Missing Covers and Add Sealant to All Covers) - (Jul 27, 2004)
#01-05-22-001 Clunk, Rattle Noise from Front of Vehicle (Replace Brake Pedal Assembly) - (Jan 16, 2001)
#01-06-02-012 Water Pump Weep (Install Coolant Collector) - (Nov 30, 2001)
#01-06-04-007A MIL Indicator Illuminated, DTC P0442 Stored (Replace Fuel Sender to Tank O-Ring) - (Apr 11, 2001)
#01-06-04-008D Inaccurate or Erratic Fuel Gauge Reading, Fuel Pump Related Driveability Concerns (Install New Fuel Tank Sender) - (Apr 3, 2003)
#01-06-04-018A Intermittent Malfunction Indicator Lamp (MIL) and PCM DTC P1404 (Recalibrate PCM) - (Sep 23, 2002)
#01-07-30-038B DTC P0757 Set, SES Lamp Illuminated, Poor Performance of Transmission, Transmission Slipping (Clean Transmission Valve Body and Case Oil Passages of Debris) - (Jan 26, 2004)
#01-08-49-016 Cigarette Lighter May Be Inoperative (Install New Lighter Element) - (Oct 19, 2001)
#01-08-52-006 Reduced Operating Range of Remote Keyless Entry (RKE) System With Blower Motor Running at High Speed (Diagnose and Install External RKE Receiver, If Necessary) - (Oct 3, 2001)
#01-08-57-003 Heater Blower Inoperative or Water on Passenger Floor (Install Sealing Strip) - (Sep 13, 2001)
#01-08-57-007A General Waterleak Diagnosis Guide - (Apr 12, 2002)
#01-08-64-012D Door Glass Sash Out of Run Channel (Repair Door Glass Sash Channel) - (Aug 19, 2003)
#01-08-64-018D Front Door Window Glass Wont Roll Up or Out of Channel (Replace Guide) - (Oct 20, 2003)
#01-08-64-020B Creak Noise When Opening or Closing Doors (Apply Lubricant to Check Link) - (Feb 5, 2004)
#02-03-08-008 Rattle/Creak/Popping Type Noise from Front of Vehicle When Turning (Replace Both Front Stabilizer Shaft Insulator Brackets) - (Nov 4, 2002)
#02-03-10-003 Scraping/Scrunching Noise from Front of Vehicle During Low Speed Turning and Braking (Clean Front Wheels and Replace Front Tires Only) - (Jun 19, 2002)
#02-06-03-005 Service Engine Soon Light with Stored Codes P0112, P0113, P111 or P1112 (Replace IAT Sensor Connector) - (Jun 5, 2002)
#02-06-03-006A No Start, No Crank, Battery, Batteries, Generator, Gages, SES, SIR, Brake, Security, Theft, ABS, Hot, DIC Messages, Lamp, Light, Battery and Generator Diagnostic Testing, and Cadillac Roadside Service - (Nov 26, 2002)
#02-06-04-009 Hesitation or Stumble on Throttle Application After Cold Start (Reprogram PCM) - (Feb 21, 2002)
#02-06-04-015 Intermittent No Crank, No Start (Clean Battery Side Terminal Stripped Threads, Replace Battery Cable Bolt) - (Mar 8, 2002)
#02-06-04-042 Service Engine Soon (SES) Lamp Illuminated, DTC P0440 Set (Replace EVAP Purge Line and Rotate Brake Booster Vacuum Hose Clamp) - (Aug 8, 2002)
#02-07-29-001 Grinding/Rattle Type Noise Coming From Transmission (Diagnose and Perform Repair) - (Jan 28, 2002)
#02-07-30-022B Service Engine Soon (SES) Light On with DTCs P0716 and/or P0717, P0730, P0753, P0758, P1860, P1887 or other Misc. Transmission Trouble Codes Set (Repair Wiring at Transaxle Wiring Pass-thru Connector) - (Oct 20, 2003)
#02-08-44-011 Poor Radio Reception (Reconnect Antenna Coax) - (Jul 25, 2002)
#02-08-45-002 Intermittent Stall, SES Light Illuminated, Loose Ground G103 (Install Washer to Tighten Ground Connection) - (Jun 13, 2002)
#02-08-49-002 Dash Rattle/Itching Noise from Instrument Panel/Glove Box Area While Driving (Reposition Body Control Module (BCM) Bracket and Insulate Blower Motor Bolt Washer) - (Apr 29, 2002)
#02-08-58-001 General Windnoise Guide - (Jan 28, 2002)
#02-08-58-004 Air Rush/Moan Noise from Rear Compartment Lid Area (Install Sealer) - (Jun 13, 2002)
#02-08-64-014 Door Glas Scratches (Widen Door Metal Inner/Outer Panel Opening) - (May 23, 2002)
#02-08-64-023A Power Window Inoperative (Replace Power Window Motor) - (Aug 18, 2003)
#02-08-66-005A Loose or Broken Rear Compartment Opening Molding (Install New Molding Assembly) - (Jul 30, 2002)
#03-02-32-001B Momentary Reduction of Power Steering (P/S) Assist On Initial Start Up With Low Ambient Temperatures (Replace P/S Pump) - (Jun 30, 2004)
#03-06-01-010B Engine Oil or Coolant Leak (Install New Intake Manifold Gasket) - (Oct 24, 2003)
#03-06-04-030A Multiple Driveability Symptoms Due to Clogged Fuel Injectors (Clean Injectors) - (Jun 24, 2004)
#03-06-04-055 Service Engine Soon/Check Engine Light Illuminated, Misfire or Roughness, DTC P0300 Set (Replace Spark Plugs) - (Sep 29, 2003)
#03064 System Software Upgrade - OBD System Improvements (Reprogram PCM) - (Dec 17, 2003)
#03-07-30-012A Transaxle or Transmission Slips, Wont Shift, No Reverse, 2nd, 3rd or Overdrive, Erratic Shifts (Replace Driven Sprocket Support Assembly) - (Oct 13, 2003)
#03-07-30-021A Neutral Flare and/or RPM Flare While In Drive, No 1-2 Upshift, Service Engine Soon (SES) Light Illuminated, Diagnostic Trouble Codes (DTCs) P1810, DTC P1815 Set (Reprogram the Powertrain Control Modul - (Nov 19, 2003)
#03-08-44-005B Poor Radio Reception or Radio Static/Increased Interference with Rear Window Defogger On or Some Rear Window Defogger Grids May Be Inoperative (Diagnose and Repair Rear Window Defogger Heating Grid) - (Jan 14, 2004)
#03-08-66-002 Wind Noise Heard From Rear of Vehicle (Adjust Primary Seal Flange) - (Jan 17, 2003)
#03-08-67-005 Water on Front Floor (Clean Drain Hose) - (Jul 15, 2003)
#03-08-67-009A Sunroof Will Not Open or close Completely (Replace Sunroof Motor) - (Mar 8, 2004)
#04-06-04-014A No Start or Immediate Stall After Start (Reprogram PCM) - (Apr 2, 2004)
#04-06-04-024 Powertrain Control Module (PCM) WIll Not Properly Communicate On-Board Diagnostic Freeze Frame Information to Non-TECh 2 Service or Test Equipment (Reprogram PCM) - (Apr 7, 2004)
#04-07-30-028 4T65-E Automatic Transmission Fluid Leak From Reverse Servo Cover (Replace Reverse Servo Cover and Seal) - (Jun 15, 2004)
#04-08-57-003 Water Leak in Trunk (Apply Sealer) - (Apr 8, 2004)
#43-17-01B BUMPS OR RUST COLORED SPOTS IN PAINT DUE TO RAIL/IRON DUST - (Jul 31, 1998)
#73-16-16A SEAT BELT LATCH SLIDES TO SEAT BELT ANCHOR SLEEVE - (Apr 14, 1998)
#83-11-15 WATERLEAK - FRONT PASSENGER FLOOR (RESEAL PLENUM/COWL - (Oct 1, 1998)
#83-15-20 DOOR GLASS SCRATCH (CHECK DIMENSION/WIDEN OPENING) - (Oct 5, 1998)
#83-15-21 'HOOT' TYPE SOUND COMING FROM OUTSIDE REAR OF VEHICLE - (Nov 23, 1998)
#83-17-02 PAINT CHIPPING AT FRONT ROCKER PANEL - (May 18, 1998)
#83-17-04 DOOR HANDLES ON WHITE PAINTED VEHICLES TURNING YELLOW - (Oct 9, 1998)
#83-30-08 STEERING WHEEL/WHEEL & TIRE VIBRATION AT HIGHWAY SPEEDS - (Oct 19, 1998)
#83-50-23 SQUEAK/SQUAWK TYPE NOISE WHEN BRAKE PEDAL DEPRESSED - (Sep 28, 1998)
#83-63-20 INACCURATE/FLUCTUATING FUEL GAUGE READING (REPLACE FUEL - (Sep 28, 1998)
#99-01-39-004A Air Conditioning Odor (Install Kit) - (May 22, 2001)
#99-02-32-002 Tech - Pwr Strng Sys Noise Concerns (Replace PSS Hose, Enlarge Sys. Restrictor) - (May 7, 1999)
#99-03-08-004 Front/Rear Stabilizer Shaft Squawk/Squeak Noise (Replace Frt/Rear Bushings) - (Jul 28, 1999)
#99-06-02-009 Coolant Leak (Repair or Replace Coolant Cap) - (Mar 8, 1999)
#99-06-03-015 Various Driveability Symptoms, SES/Generator Light On (Replace Battery/Generator) - (Dec 20, 1999)
#99-06-04-005B Driveability Symptoms Due to Clogged Fuel Injectors (Clean Injectors) - (Aug 24, 2001)
#99-06-04-050 Hesitation Or Lack Of Power On Acceleration (Reprogram PCM) - (Oct 21, 1999)
#99-07-30-031 DTC P0730, No Third and Forth Gear (Replace Direct Clutch Piston Assembly) - (Dec 13, 1999)
see part 2 later in this post
Old 09-12-2002, 09:34 AM   #2
iceman
woop woop
iceman's Avatar
AKA: Seth
Part 2
#99-08-45-005 Accessory Receptacle is Inoperative (Check Aftermarket Device Plug) - (Nov 8, 1999)
#99-08-49-008 Chime Sounds When Key is Removed from Ignition (Inspect/Replace Lock Cylinder) - (Jun 25, 1999)
#99-08-51-010 Paint Chipping at Front Rocker Panel (Repair Paint/Install New Rocker Molding) - (Dec 6, 1999)
#99-08-64-004 Run Channel(s) Loose to the Door Frame (Replace Run Channel) - (Apr 13, 1999)
#99-08-66-005 Distortion in Top Surface/Water Inside Rear Spoiler (Add Vent Holes) - (Jun 18, 1999)
A good explanation of what a TSB is and how to use them is here:
http://www.grandamgt.com/forum/showt...&threadid=1137
Old 03-20-2003, 09:17 AM   #3
iceman
woop woop
iceman's Avatar
AKA: Seth
Updated 3/20/03
Old 07-19-2003, 09:19 PM   #4
cargt2000
Guest
Posts: n/a
I'm replacing my 3.4 engine with only 60k miles. I'm lucky that my warrenty is covering it . To let you know there are about 50 TSB's on this engine. I'm in the Army, another soldier in my same BN is having the same problem. Our cars are 2000 Grand Am GT's. Engine codes are M . The only differents in the two cars is his is a two door while mine is a four door. My question is what are the odds the two cars have the same problem,within mayby a mile apart. IF THERE IS ANYONE OUT THERE WITH THIS PROBLEM LET ME KNOW ........ IT STARTS OUT AS A LOUD TAP, THAN GETS WORSE. The classaction over the coolent may be just the beginning for GM.....
Old 12-26-2003, 10:29 AM   #5
iceman
woop woop
iceman's Avatar
AKA: Seth
Updated 12/26/03
Old 01-08-2004, 09:01 AM   #6
PACE
Woooo Woooooooo !
PACE's Avatar
AKA: Jason
Vehicle: GRAND AMERICAN
PACE has disabled reputation
#00-05-23-002B Front Disc Brake Pulsation (New Rotor Run-Out Specification and Correction Method) - (Mar 5, 2003)
Is this the only "warped rotor" related TSB ? My car is at the dealership and I know they are going to blame my blown wheel bearing on my powerslots.....Any other brake related TSB's? Thanks Seth!
Grand Am---Long gone.
2009 Yukon Denali with 4" drop on 24" black Escalade wheels -- in the garage
1970 Impala convertible triple black - In the Garage
PACE is offline   Reply With Quote
Old 01-08-2004, 09:15 AM   #7
iceman
woop woop
iceman's Avatar
AKA: Seth
That's all I can see..
Old 05-29-2004, 09:39 AM   #8
gtaholic
Ride Red Baby!!!!!
gtaholic's Avatar
Vehicle: 2000 GAGT Coupe
gtaholic Gettin' there
Hey Iceman,
What's up Bro? I am a long time member here and just came back for some info. I wanted to thank you for the list you have put together for the GA owners here. Very helpful when dealing with warranty issues.
Only one suggestion. Could you space them out per TSB so it is easier to read. One hell of a run on list.
Just a suggestion
2000 Grand Am GT
http://www.sounddomain.com/member_pages/view_page.pl?page_id=126311
2003 Honda CBR F4i
gtaholic is offline   Reply With Quote
Old 07-27-2004, 09:23 AM   #9
FyberDesignz
Guest
Posts: n/a
<quote>#03-07-30-021A Neutral Flare and/or RPM Flare While In Drive, No 1-2 Upshift, Service Engine Soon (SES) Light Illuminated, Diagnostic Trouble Codes (DTCs) P1810, DTC P1815 Set (Reprogram the Powertrain Control Modul - (Nov 19, 2003) </quote>
In this code what is meant by a flare? I am having some tranny issues and it has always sorta revved a little while at a constant speed but I thought nothing of it. Just today it started not upshifting from 1-2 and maybe they are related. Cruise control has also been an issue with it cutting in and out for no apparent reason. Hopefully with some of these codes they can figure something out.
Thanks for all the information.
Old 07-30-2004, 07:43 AM   #10
iceman
woop woop
iceman's Avatar
AKA: Seth
Updated 7/30/04 .. buncha new ones folks.
Old 09-23-2004, 08:46 PM   #11
GrahamKracka
WannaBe Fat Kid
GrahamKracka's Avatar
AKA: Richard
Vehicle: 2005 Nissan Titan
GrahamKracka Gettin' there
Send a message via AIM to GrahamKracka
why is the 4t65e listed on a tsb for a grand am?
GrahamKracka is offline   Reply With Quote
Old 12-20-2004, 09:40 PM   #12
JermsGAGT03
JermsGAGT03 Gettin' there
please do not tell me all those items mentioned in the first two post are recalls. I've never recieved anything from GM and alot of the things mentioned I am currently having problems with. I don't know about everyone else cars but mine has been a piece of sh** since the day I bought it and I'm really starting to get tired of having it in the shop every week.
JermsGAGT03 is offline   Reply With Quote
Old 01-26-2005, 06:25 PM   #13
websgt1
websgt1's Avatar
Vehicle: 2001 Grand Am GT 1
websgt1 Gettin' there
when i'm driving about 70 mph on the highway i hear a humming noise from the back of my car. when i open the sunroof it goes away. i was wondering if the air flowing off my spoiler
websgt1 is offline   Reply With Quote
Old 04-08-2006, 11:02 PM   #14
BigTaters
Local Pimp
BigTaters's Avatar
AKA: Derek
Vehicle: 2000 G.A. GT
BigTaters Gettin' there
Send a message via ICQ to BigTaters Send a message via MSN to BigTaters Send a message via Yahoo to BigTaters
dexcool is not the problem. there is nothing wrong with dexcool it is the best coolant u can buy for the money.. it is just very powerful.. the problem with our cars and many others with 3.4's in them is the gaskets they used and they way they fit.. the dexcool eats them (in 2003 they corrected this).. there is a big fuss in canada and the us now about gm hiding this problem.. i am hoping for a recall of all 99-02 grand ams so i can get mine fixed.. i dont want to pay 800-900 to get it fixed.. about 100 in gaskets.. the rest is labour
Mustangs are for useless fat girls.
BigTaters is offline   Reply With Quote
Old 04-21-2006, 02:15 AM   #15
TheOak
TheOak's Avatar
AKA: Rob
Vehicle: 2002 Grand Am se1 v6
TheOak Gettin' there
have they recalled this yet? and if they do its free to any car owner who takes it into the dealer correct?
this is my first car,I have no idea how recalls work
TheOak is offline   Reply With Quote
Old 04-21-2006, 02:29 PM   #16
TheOak, check your pm's for a short explanation.
Old 09-18-2006, 12:41 PM   #17
NorKoastal
WhiteOutGT
NorKoastal's Avatar
AKA: Brad
Vehicle: 2000 GA GT Coupe
NorKoastal Gettin' there
Send a message via AIM to NorKoastal
Just got back from the dealer... They said there are issues with my outer Tie Rods. They said a TSB was issued for rough casting I think.. Does anyone have this???
How difficult would a Tie Rod replacement be?
NorKoastal is offline   Reply With Quote
Old 06-09-2007, 12:24 AM   #18
GrandIllusion
My Son Is My Fuel
GrandIllusion's Avatar
AKA: Steve
Vehicle: 1994 Grand am Coupe SE
GrandIllusion Gettin' there
Send a message via ICQ to GrandIllusion Send a message via AIM to GrandIllusion Send a message via Yahoo to GrandIllusion
hey someone print this off and take there car to a pontiac dealer and tell them to fix all the recalls and see what they say then get back to me about it. im half tempted to try it.
///Steve-O
Relaxed Atmosphere
1991 chevy 4dr layin rockers on 22's with a CUSTOM 1 off frame
1985 Nissan 720 bagged on escalade wheels daily when no rain .
2002 Chevy Tahoe daily
GrandIllusion is offline   Reply With Quote
Old 07-14-2007, 11:57 PM   #19
TFA
TFA's Avatar
TFA Gettin' there
Send a message via AIM to TFA
did you read the section on "how to use TSBs"? they arent recalls either, they are just known problems...and as it states in the how to use section, dealerships are not obligated to fix them free of cost unless the car is under warenty
'03 GT.
Old 09-08-2010, 09:49 AM   #20
grandam3400
grandam3400's Avatar
Vehicle: 1999 Grand Am GT coupe
grandam3400 Gettin' there
Does anyone have access to the procedures on how to fix these issues?
grandam3400 is offline   Reply With Quote
