Old 06-30-2012, 01:29 PM   #261
Aug06
Vehicle: 2000 SE
Aug06 Gettin' there
Question
My speed 1 & 2 stopped working, does this affect the air conditioner on speeds 3-5? or will the air conditioning still work on these speeds?
Aug06 is offline   Reply With Quote
Old 06-30-2012, 02:40 PM   #262
street_fire
street_fire's Avatar
street_fire Gettin' there
Blower Motor Resistor
http://www.grandamgt.com/forum/showt...&threadid=1346
Old 06-30-2012, 02:41 PM   #263
street_fire
Everything still works on 3-5. It's a cheap fix. Not more then $20 part.
Old 06-30-2012, 02:54 PM   #264
$20 part, tedious to replace.
You need a lot of patience and tiny hands to keep from losing the bolts. Then of course the fun of inserting the new resistor without damaging it.
Old 06-30-2012, 03:14 PM   #265
Aug06
Vehicle: 2000 SE
Aug06 Gettin' there
Just recharged the A/C, works great now, temp shows about 45 degrees, I would change the resistor but the problem is my fingers are the size of sausages and I dont mean the tiny links either, so that project will test my patience for sure, I am just happy to have the A/C back, the resistor is a project far maybe in the future.
Thanks for advice, I didnt want to recharge the A/C if it wasnt gonna work without the 1st the fan speeds not working.
Mike
Old 06-30-2012, 03:23 PM   #266
Just drop the panel under your glovebox, the resistor is behind the blower motor.
Old 07-12-2012, 10:01 PM   #267
jlyric414
jlyric414's Avatar
AKA: John
jlyric414 Gettin' there
Does anybody know if a bad Resistor could cause none of the fan speeds to work. I replaced the resistor before about 5 months ago and it worked just fine and now its out again. So Im wondering is it just the resistor or could there be and underlying problem?? its sucks not having A/C!
185 Tire Scorching Horse Power! LMFAO
jlyric414 is offline   Reply With Quote
Old 07-12-2012, 10:15 PM   #268
pongagt
pongagt's Avatar
AKA: Sigmund
pongagt Gettin' there
It can't be the resistor board since the high fan speed full battery power wire does not go through it. Check the blower motor fuse, blower motor relay, relay ground, and motor ground. You should also check the switch with a volt or ohm meter. If all that is ok it is a bad motor. You can check to see if the motor is getting power so you can see if the motor is bad before you check anything else.
pongagt is offline   Reply With Quote
Old 07-12-2012, 10:16 PM   #269
pongagt
pongagt's Avatar
AKA: Sigmund
Old 07-13-2012, 04:53 AM   #270
Cheap parts can also be the problem. I replaced mine back in January, still works fine. Either that, or you have a short. But it would be a lot quicker to burn out. I'm opting on it being a crappy part.
Old 06-03-2015, 10:58 AM   #271
2000 GT
AKA: Nate
Vehicle: 2000 Grand Am GT 3.4L
2000 GT Gettin' there
My blower motor cuts out anytime i switch it to level 4 or 5. Then it won't work for awhile and i'll just be messing around with it for awhile and it'll kick back on within a few days. Recently it stopped working all together i'm unsure if my mechanic was checking it out (since i told him about it) or the problem is worse to where it doesn't work at all.. i know though it doesn't like heat, i think the motor is bad but maybe other reasons? Sounds like a pain to fix though, maybe hitting it would kick it back on?
2000 GT is offline   Reply With Quote
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
