Old 02-21-2011, 05:27 PM   #1
turdstangjunk69
turdstangjunk69's Avatar
AKA: travis
Vehicle: 2000 grand am gt sedan
turdstangjunk69 Gettin' there
removing transmission
Quick question for those who removed their transmissions. What's the best way to get it out?cause I am looking at it and does not look like its gonna come out very easily.
2000 GT Black Sedan, 5% Tint, Smoked Tails, Reverse and Third, Debadged, Painted Black Chrome Techs, DDM Tuning's 8k HID Fog and Headlights. Sprint Springs with Monroe Struts. Camaro Brake Upgrade.
turdstangjunk69 is offline   Reply With Quote
Old 02-21-2011, 07:33 PM   #2
XtremeGaGt00
converted to ls1 :)
XtremeGaGt00's Avatar
AKA: Jason
Vehicle: 00gagt 99gtp 99t/a
XtremeGaGt00 Gettin' there
you gotta drop the cradle.
Old 02-21-2011, 08:05 PM   #3
icecats87
icecats87's Avatar
AKA: Dylan
Vehicle: 2001 Grand Am Gt
icecats87 Gettin' there
yep dropping the cradle is the way spent 3 maybe 4 hours today in calss im changing transmissions on mine right now, going pretty smoothly only thing is cant find out where to disconnect the fuel lines my teachers looking it up, hope to have it out Wednesday during class
icecats87 is offline   Reply With Quote
Old 02-21-2011, 08:35 PM   #4
You can take it out the top too if you want to remove the engine as well.
Old 02-21-2011, 09:01 PM   #5
turdstangjunk69
AKA: travis
Yeah holy crap. Removing the sub frame sucked. I think I would have been better off pulling whole motor. Not a very fun job. Plus all the bolts are super tight for some reason. Ugh not nice.
Old 02-21-2011, 09:04 PM   #6
XtremeGaGt00
converted to ls1 :)
AKA: Jason
no need to disconnect your fuel lines...
Old 02-21-2011, 09:15 PM   #7
icecats87
icecats87's Avatar
AKA: Dylan
I thought they ran from the fuel rail and all the way back to your gas tank under the car, and when you lift the body up they wont stay with the engine they will go up with car
Old 02-21-2011, 09:37 PM   #8
XtremeGaGt00
converted to ls1 :)
AKA: Jason
you plan on lifting the body off? if youve got a lift and the proper jack id just drop the cradle. keep the engine in the car, should even havta mess with the fuel lines at all.
Old 02-21-2011, 09:53 PM   #9
icecats87
icecats87's Avatar
AKA: Dylan
Im not sure my teacher just said to get all the wiring disconnected the compressor, downpipe, and just hoses and then put the frame on jack stands un bolt it use the lift to lift car up and engine and tranny should be on the jackstands and frame, does this sound correct?
Old 02-21-2011, 10:05 PM   #10
XtremeGaGt00
converted to ls1 :)
AKA: Jason
thats a method you can do it, but i think your just removing far more then you need to..im guessing your class does not have the proper engine supports to pull a cradle?
Old 02-21-2011, 10:11 PM   #11
icecats87
icecats87's Avatar
AKA: Dylan
im not sure it might but ive been just pulling everything my professors says so i dont know its almost out so i guess what im doing is working just more time consuming
Old 02-21-2011, 10:23 PM   #12
turdstangjunk69
AKA: travis
Anyone know about the pull type connectors that go to the heater core hoses? I broke one of them. Are they necessary or can I just connect it straight to the pipe to the hose without that connector thing?
Old 02-21-2011, 10:25 PM   #13
This is one of those jobs that the Haynes manual is pretty useful....
Supporting the engine from the top side is tricky: if the support takes up too much room above the engine, and you leave the hood on, make sure there is enough clearance to the ceiling when you lift the car.
If I had to do that job ever again, I would pull the engine / tranny out the top.
Particularly difficult was replacing the steering wheel linkages into the properly aligned location while reinstalling the subframe (cradle).
Old 02-22-2011, 06:45 PM   #14
turdstangjunk69
AKA: travis
Anyone know about the heater core hose clip things?
Old 02-22-2011, 06:58 PM   #15
XtremeGaGt00
converted to ls1 :)
AKA: Jason
you can just clamp them with worm clamps
Old 02-22-2011, 07:31 PM   #16
turdstangjunk69
AKA: travis
Ok cool thanks
