Old 04-16-2017, 11:13 PM   #361
Nice update. That turbo 3100 must be funny hearing that spool
2000 - GAGT 14.63@92.9 -Full LX9 with CAI, 65MM TB, 2.5in DP, Borla Cat-Back, Crappy rubber, Magic, Quick tune)
1984 - Honda Nighthawk 700s - Oldest, quickest and quietess
Old 04-17-2017, 08:38 PM   #362
tw0123
osv in progress
tw0123's Avatar
Vehicle: 2002 Alero
tw0123 Gettin' there
That's awesome Mike!! Those tires are toast hahaha !!!!!
Old 04-18-2017, 05:42 PM   #363
O1GAGT
AKA: Phil
O1GAGT Gettin' there
More info needed on the turbo 3100 swapped into the truck!
Old 04-18-2017, 05:54 PM   #364
I believe there is a build on 60degreev6 but i haven't been on there really since the forum update
Old 04-19-2017, 02:27 PM   #365
_HeC_
_HeC_'s Avatar
_HeC_ Gettin' there
Originally Posted by 3400cavyhatch View Post
This thing is pretty quick, would really like to see how it goes with traction and a straight line! I don't see why it shouldn't do 12's this year if it hooks! I'm really starting to think of a 5spd for the Alero now too! Lol
Do it, you know you want too! 3900/5spd would be fun
Scott(3400cavyhatch) is the man to talk to about that
The new tune Scott did really feels good too, hitting 79% duty cycle on those GTP injectors though if I remember right other people running them were around 300whp when maxing them out?
3pc wheels followed me home yesterday, now I can go back to 245 tires
Turbo 3500/5 speed swapped
The Build
IG - turbogagt
Old 04-19-2017, 09:22 PM   #366
3400cavyhatch
Vehicle: 84 Cavalier Type 10
3400cavyhatch Gettin' there
I have a build thread here: http://www.60degreev6.com/vb5/forum/...nto-1993-c1500
But I have not updated it in a while, hopefully soon (waiting to add some action footage! )
Yes it would! Even with an auto it would be!
1993 Chevy C1500 3100v6 turbo
2004 Alero 3400 bone stock with a cheap muffler 15.32 @ 88.69
99 Alero 3500 swap running(from 2.4). ported and polished heads. totaled by a honda
2002 GAGT 3500 swap
3400cavyhatch is offline   Reply With Quote
Old 04-23-2017, 11:52 AM   #367
Yeah, I remember reading somewhere that the GTP injectors were actually more like 33 lb/hr at normal fuel pressure ratings, but like 36/hr at the fuel pressure in the car, so the actual flow rate depends on the calculation you're using? But I had them pegged at 320 whp. Injector pulse width went up until around 4800 rpm on the dyno then stayed static, and my AFR started leaning out from 5000-6300 rpm (by almost a full point), so they were definitely maxed. I pulled them and went back to Lucas 42's.
Old 07-06-2017, 11:21 AM   #368
_HeC_
_HeC_'s Avatar
_HeC_ Gettin' there
2 3500s??
WOT-Tech cam, yellow LS6 valve springs and P&P Intake manifolds this time. Also fixing my turbo crossover, one of the GM flex bellows cracked on me
The Build
IG - turbogagt
Old 07-11-2017, 07:26 PM   #369
_HeC_
_HeC_'s Avatar
_HeC_ Gettin' there
Got the crossover patched up and new motor up and running a little while ago, huge thanks to Scott for hooking me up with the engine
Old 07-27-2017, 01:03 AM   #370
heh, I see you are getting the same notices from photobucket about 3rd party hosting. I just got one of those the other day. Never used to matter... they always allowed hot linking for free. Now apparently they've changed their policy, and I never got an email notification about it. Oh well.
Old 08-20-2018, 07:08 AM   #371
_HeC_
_HeC_'s Avatar
_HeC_ Gettin' there
Nice to see photobucket went back to 3rd party hosting
The Build
IG - turbogagt
Old 08-20-2018, 09:24 PM   #372
tw0123
osv in progress
tw0123's Avatar
Vehicle: 2002 Alero
That hood looks better on your car ����
Btw, any issues with it clearing the spacers?
Old 08-27-2018, 04:25 PM   #373
Noice
Old 12-30-2018, 10:40 PM   #374
3400cavyhatch
https://youtu.be/MBlmuz77Avo
This was Mike's first run with this set up, traction was the biggest issue, and it was a bad day for test and tune because there was probably 150+ cars racing, and lots of break downs. I ran my truck as well but didn't get a video managed a 15.84 @ 85 mph on 6.5 psi!
Can't wait to see it in the new year once he gets the 3" exhaust on it and some more passes!
2002 GAGT 3500 swap
