Old 05-01-2017, 06:17 PM   #1
George
AKA: George
Vehicle: 2000 Grand AM GT
George Gettin' there
2000 Pontiac Grand AM GT Dash Repair Curving
Hello
I have a 2000 Pontiac Grand AM GT 4 door that has the dash board curving up at the windshield as well at the Bezel that is in front of the instrument cluster.
I have seen the video and the rubber tubing repair trick for the dash at the wind shield BUT how do you repair the dash that has curved up at the top of the Bezel above the instruments so that it fits back into the Bezel covering it?
Videos are BEST if you can point me to.
Thanks in advance for your help.
George
George is offline   Reply With Quote
Old 05-02-2017, 07:06 AM   #2
Some people has tried to heat it up, put some high strength glue on it and use a clamp to hold it together, but will ultimately go back the same way again. There is no permanent solution to our dash curling.
Old 05-03-2017, 08:05 AM   #3
2000 GT
AKA: Nate
Vehicle: 2000 Grand Am GT 3.4L
2000 GT Gettin' there
I wonder if you could screw it in someplace. May have to remove some of that dash foam material.
2000 GT is offline   Reply With Quote
Old 05-11-2017, 05:49 AM   #4
louisville
GA Addict
louisville's Avatar
AKA: jimmie
louisville Gettin' there
Go to your local auto parts store and buy 5 ft of hose . 3/4 inch is perfect. Cut ends to a 45 degree angle and push into place/ the windshield and dash will hold it in place. Almost looks like it is supposed to be there. It will hold dash down and with the summer heat , it will mold it back into place ! Worked for me !
louisville is offline   Reply With Quote
