Old 10-09-2008, 08:15 PM   #1
gandolf77
Vehicle: 1999 Grand Am GT
gandolf77 Gettin' there
What is it that leaks from synthetic oil?
I've always used synthetic blend oil and am thinkin about switching to full synthetic. Here's my situation: my grand am has 100,000+ miles, I recently had the LIM done, so they changed the upper & lower gaskets and they machined the cylinder head as well, so none of that should have gunk built up that would loosen & leak. So, does the gunk build up somewhere else that I would have to worry about it leaking? Or am I in the clear to switch to synthetic. Thanks for the help guys, I just don't know enough about the inside of engines.
gandolf77 is offline   Reply With Quote
Old 10-09-2008, 08:24 PM   #2
GrandAmGT-2008
GrandAmGT-2008
AKA: William
Vehicle: 2000 GA-GT Coupe
GrandAmGT-2008 Gettin' there
Send a message via MSN to GrandAmGT-2008 Send a message via Yahoo to GrandAmGT-2008
in the clear i do beleive
Just because you can speed, DOESNT mean your car is fast!!
My CarDomain!!
GrandAmGT-2008 is offline   Reply With Quote
Old 10-09-2008, 08:25 PM   #3
XtremeGaGt00
converted to ls1 :)
XtremeGaGt00's Avatar
AKA: Jason
Vehicle: 00gagt 99gtp 99t/a
XtremeGaGt00 Gettin' there
the only bad thing with synthetic is that it will find all the weak gaskets and start leaking from them, the ones that are starting to dry rot..or will leak in the near future...
Old 10-09-2008, 08:27 PM   #4
GrandAmGT-2008
GrandAmGT-2008
AKA: William
only one left to leak oil would be the oil pan gasket.... but then again he is already running a blend.
My CarDomain!!
Old 10-09-2008, 08:38 PM   #5
XtremeGaGt00
converted to ls1 :)
AKA: Jason
oil pan gasket...front main gasket..rear main gasket..oil pump drive gasket...front timing cover gasket...valve seals<--(doubt them will though)
Old 10-09-2008, 08:41 PM   #6
cardude007617
mmm turbo boost
cardude007617's Avatar
cardude007617 Gettin' there
Send a message via AIM to cardude007617 Send a message via Yahoo to cardude007617
so its safer to run semi synthetic than full syn with an older car? i recently made the switch to semi and love it. but hell ill switch back if it does damage
Old 10-09-2008, 08:54 PM   #7
Malaclypse
Wrenched Loose
Vehicle: 2013 Malibu 2LT
Malaclypse a trusted member
It really shouldn't make a difference because the viscosity of the oils is a standard set that they -must- meet.
That said, synthetic oil is no more thick or thin than conventional. You should be fine to go full synth.
Malaclypse is offline   Reply With Quote
Old 10-10-2008, 02:06 AM   #8
Wubby{Beat
Wubby{Beat's Avatar
AKA: It's Midnight
Vehicle: 04 Grand Am GT
Wubby{Beat Gettin' there
what about 0w30 castro syntec made in germany, have heard its fine to run in ours, even all year round, but someone told me on automotiveforums that he wouldnt run it, he has a GA as well and does know fair bit, what are your guys opinions? have 165k km, been running syntec 5w30 since 130k km when I got it
have had no leaks in my time owned, over a yaer now
Audio: Alpine All Around - CDA-9886 - SPR 6x9s - SPX 5.25s - MRV-F345 - SPR 12'' Sealed - PDX 1.600
Mods: MP Racing Tune, 2.5'' SLP Catback Exhaust, 2.5'' Magnaflow Cat, WAI, MSD 8.5mm Wires, NGK Iridium Plugs, Lowered on Eibachs and KYB GR-2s, Front + Rear EZ STBs
Wubby{Beat is offline   Reply With Quote
Old 10-10-2008, 08:01 AM   #9
SSRacer
Speed Racer
SSRacer's Avatar
AKA: Sean
SSRacer Gettin' there
I've been running royal purple full synth for years. Almost 90K now...no leaks or other issues.
2002 Pontiac Grand Am GT1
Old 10-10-2008, 11:13 AM   #10
blondiez24gt
blondiez24gt's Avatar
AKA: Leslie
blondiez24gt Gettin' there
I got My cavalier Z24 from My Aunt when it had 116,000 miles on it. She had always used valvoline. Well I switched to Mobile 1 Full synthetic at 116,000 miles. I'm up to like 15X,XXX. I haven't had a leak since I switched to it.
blondiez24gt is offline   Reply With Quote
Old 10-10-2008, 02:52 PM   #11
x2
Old 10-10-2008, 03:30 PM   #12
3800SII
3800SII's Avatar
AKA: C BOYD
Vehicle: 2004 GRAND AM GT
3800SII Gettin' there
Good stuff! If you are on the cheap side like me just throw in 3.5 quarts of standard oil and a bottle of Lucas Oil Stabilizer. The BEST stuff in the world to me.
I use this method on both my Firebird V6 and GrandAM GT. Cars have 169,000 and 79,000 miles respectively.
ABSOLUTELY NO OIL LEAKS ANYWHERE!
Old 10-10-2008, 09:03 PM   #13
Malaclypse
Wrenched Loose
I've been running that oil exclusively in my Cobalt since 5k miles and I ran it in my Monte for 30k miles or so. Great oil but I've switched back to Mobil conventional for cost reasons... an $18 oil change is nice.
Old 10-10-2008, 09:47 PM   #14
Mike Jung
400 hp & 410 lb-ft
Mike Jung's Avatar
Mike Jung a trusted member
German Castrol Syntec 0W-30 synthetic motor oil ?
Never heard of it
Why can't you run it all year long ?
(Doesn't sound like that guy on that automotiveforums knows much about 'GC'.)
I do
But it is really better during the summer hotter months though.
PS: Paying $8.99 Cdn per 1L bottle does suck though.
So I stock up during sales.
Old 10-11-2008, 01:01 PM   #15
Wubby{Beat
Wubby{Beat's Avatar
AKA: It's Midnight
Never heard of it
I do
yea its extremely expensive, however per 1L bottles its the same as any other, but who buys 1L bottles
where I live however it doesnt get totally cold like it does in terana (used to live there for 3yrs, born there, where my cars from), maybe -10c for a month or so
should I stick with my syntec 5w30 or switch to 0w30 GC at 165k km is the question?
Old 10-11-2008, 03:27 PM   #16
I'd like to know what they supposedly machined on the cylinder heads. Why would they do that? And did they take them off the block? You can't machine something properly while it's in the car, plus there's the risk of getting metal shavings in your engine. There wouldn't be any reason to machine anything anyway, it's not going to make it seal better. I'd say the shop that did your work is full of crap.
Old 10-11-2008, 10:06 PM   #17
Mike Jung
400 hp & 410 lb-ft
Mike Jung's Avatar
German Castrol Syntec 0W-30 synthetic motor oil...
It is obvious that you haven't bought German Castrol Syntec 0W-30 synthetic motor oil before
IT ONLY COMES IN 1L BOTTLES !
(or 1 US Quart bottles in the US.)
Is it worth it to change from US Castrol Syntec 5W-30 to German Castrol Syntec 0W-30 ?
Hell, yeah !
I run all year round.
with a NAPA Gold 1036 (oversized, similar to an AC Delco PF-52 in size) oil filter.
Old 10-12-2008, 12:17 AM   #18
gandolf77
When they did my LIM, there was coolant leaking from the head gasket. So they had the cylinder head machined and they replaced the head gasket.
Old 10-12-2008, 12:48 AM   #19
gagt Mechanic
AKA: Jordan
Vehicle: 04 GAGT Coupe
gagt Mechanic Gettin' there
the purpose of full syn is that it wont break down as fast. when oil breaks down, gets carbon build up, dirty, it becomes thicker. so if you have oil leaks and switch to syn, they will not leak worse, just longer and more efficient.
as far as 0w30 I would be weary of proper lubrication, and proper oil pressure.
gagt Mechanic is offline   Reply With Quote
Old 10-12-2008, 12:51 AM   #20
Mike Jung
400 hp & 410 lb-ft
Mike Jung's Avatar
Originally Posted by gagt Mechanic View Post
...as far as 0w30 I would be weary of proper lubrication, and proper oil pressure.
Please explain ?
No one on BITOG forum has express any concerns in the 6-years of using GC.
leak, synthetic
