Old 03-27-2018, 04:09 PM   #1
Owned car since 2003
Headlight Trouble!! Need help please!
Hey everyone. My driver side headlight isn't working. Neither high or low beams. There must be some power because the shine very very dim. First i tried new bulbs. Then a brand new headlight assembly. Then I cleaned the headlight connector. Then I replaced the connector with a new one. Fuses are good. But could it even be a fuse, relay or switch when the passenger headlight works perfectly fine? Bad ground between fuse box and connector??? I sure hope somebody can help me figure this out. Thank you.
[SIGPIC]
Old 03-27-2018, 08:01 PM   #2
Sounds like a bad ground on the ground pack.
Old 03-27-2018, 08:11 PM   #3
Is that under or in the fues box?
[SIGPIC]
Old 03-28-2018, 07:18 AM   #4
This might be helpful. http://s424.photobucket.com/user/Pha...?sort=3&page=1
Old 03-29-2018, 01:10 PM   #5
nivek98
nivek98's Avatar
AKA: Nivek
nivek98 Gettin' there
Send a message via Yahoo to nivek98
Get a voltage meter on the headlight connector to check your 12VDC.
nivek98 is offline   Reply With Quote
Old 03-29-2018, 04:04 PM   #6
I am getting 12v out of the pink wire. The other two are ground? Also I read the circuit goes to the dimmer switch. Was that meant to say multi function switch? Or is it possible my dimmer switch is bad?
[SIGPIC]
Old 03-29-2018, 04:36 PM   #7
i had a similar situation. i think one of the wires is suppose to be a switch wire. i ended up running a wire from the fuse box, 30 amp fuse the controlled the left side head light. shoved a bare wire under the part of the fuse closest to the headlight, and then ran that wire to the harness. its been working for years. a lot of times with random electric issues, its a bunch of trial and error. i wish i could remember the wire colors but its been since before my son was born, and he's 4 now, so at least that long.
also my guess as to why your getting a very dim light is from your DRL's.
Old 03-29-2018, 04:38 PM   #8
Thanks for the info. I'll keep trying.
[SIGPIC]
Old 04-02-2018, 07:29 PM   #9
nivek98
nivek98's Avatar
AKA: Nivek
Multifunction switch has been the culprit on a couple other problems... Not sure you can get to the contacts to clean them since the switch is inside the stick but maybe worth a shot to inspect or replace if you had access to a spare. The switch controls the ground side of power to headlight. Double check wiring from headlight to fuse block under hood.check this link...https://www.justanswer.com/pontiac/3...tch-cause.html
